Topic: Cannot get any audio output with 9652 and ADA8000
On advise from a friend to upgrade my system I recently purchased a 9652 card and have it set to where my inputs are the ADA8000 into the ADAT out of that card plug in to the ADAT1 in on the 9652. I am able to have sgnal in as I see it in my DAW and in Total Mix.
Output is from ADAT1 out of the 8652 into the ADAT in on the ADA8000. Zero sound, nothing I have tested the ADA8000 on another system and it does work. I cannot figure out for the life of me how to ensure I have properly routed the output signal because I am trying to make sense of three different manuals where none of the manuals reference any of the setting windows installed through the current drivers. This is an on going issue over the past two weeks and I am about to call it quits and return the RME card. The only reference while using the search function on this forum is one where tech support tells the author of the thread to reference the other thread with no way to know what thread he was talking about.
At this point I dont know what to do and losing faith in this piece of gear fast.
