Topic: Digicheck does not work well with RME ADI2PRO
If I lanch digicheck 5.92 playback is frequently interrupted.
I updated both firmware and ASIO with the latest versions as per today
thanks much
DAW: W10 mini PC (i5)
Server: JRiver 30+Dirac+Acon Declick
DAC: RME ADI2 PRO Speakers ATC SCM50ASL
Re: Digicheck does not work well with RME ADI2PRO
Please explicitely name version numbers to be clear on that and to be able to follow this thread after weeks/months.
1. Whats the driver name and version for ADI-2 Pro
2. What Windows 10 version do you have exactly ? 1909 2004 ? Is this the Pro version ?
3
You checked CPU load, sample rates and buffer size?
W10PRO
OS build 19041.450
120.2212.31.0
driver: 09722
Update to firmware revision MADIface XT: 191/56/42, USB: 25, Pro: 73. OctaMic XTC: 47/26. ADI-2 Pro: 213/98, ADI-2 DAC: 27/34, Digiface USB: 14, UFX II 20/11/7.
5 (edited by stanzanim 2020-08-25 10:23:23)
how can I set / check buffer size and sample rates?
The only suitable way is from JRiver Audi->Audio Device'>Device Settings and then Output: Open Driver Control panel which is set to 192KHz (same output SF from JRiver playback)
ADI2PRO FS is set to INTernal - i.e. determined by the source
6
Settings dialog, see manual Chapter 24.1 Settings Dialog.
For DIGICheck: F3, do not check the sample rate setting, and check the current value during operation on the window bottom right.
ok thanks. I get the same dialog box displayed by JRiver which in fact communicate with the ASIO driver
Sample rate and buffer size are set as expected (192 KHx FS is determined by JRiver output since clock source is set to internal, right?)
8
Buffer Size is set to what exactly? Do you see USB errors in the Settings dialog when DIGICheck is running?
I tried with max 8192  and Min 128 buffersize ... No USB errors
10
You need to check how much CPU is used when both programs run at the same time, and also have a check with the Latency Monitor from Resplendence.
Also make sure the ADI-2 Pro is not selected as Default Playback device in the Sound control pannel, tab Playback. Systemsounds etc might cause interruptions during music playback.
