Topic: ADI-2 Pro outputs.
I am contemplating either purchasing the ADI-2 FS or the ADI-2 FS Pro. I am interested in using the four outputs to 4 different amplifiers, bypassing a preamplifier. Would the Pro be better suited for this or should I split the output of the ADI-2 FS instead?
Thanks,
drb
2 (edited by KaiS 2020-09-08 23:11:00)
Re: ADI-2 Pro outputs.
If you don't need different signals (DSP processing, EQ, different sources) or separate volume control you can split the ADI-2 DAC's outputs to as many amplifiers as you want.
That's true for almost every analog output, except most direct coupled tube preamps.
I will not have different sources, but DSP processing and EQ might be helpful.
Thanks,
drb
4 (edited by KaiS 2020-09-09 08:22:52)
ADI-2 DAC has one stereo DAC and output (split to XLR balanced and Cinch unbalanced), with one instance of DSP processing total.
ADI-2 Pro has two stereo DACs and outputs, plus a stereo ADC and analog input, with a total of three instances of DSP processing.
ADI-2 FS - the one without LCD display - has stereo i/o and no DSP.
