1 (edited by GabrielB 2020-09-15 14:36:10)
Topic: TotalMix FX effects section broken - UFX
The effects section of TotalMix FX seems to be broken. With no input being fed to the FX (all sends at -inf) the FX section is outputting full-scale distortion. It sounds similar to a corrupt/unsynchronized audio stream but it's level and character changes depending on the FX parameters. I have tried updating/reinstalling drivers, re-flashing the latest firmware, and changing the sample rate.
The issue is primarily with the Echo but it's also present with the Reverb and it is still present when operating the interface in a standalone capacity. I have no other noise or distortion issues on any channels, and the rest of TotalMix FX seems to work fine.
Driver version: 1.168
Firmware version: USB 360, Firewire 344, DSP 163, USB (Class Compliant) 28
Re: TotalMix FX effects section broken - UFX
Did you manage to fix this?
Eastwood Records
www.eastwoodrecords.co.uk
3
Most probably by using the search function of this forum. Mentioned often enough - DSP / RAM error.
