Topic: Powering the ARC USB
HI there,
I just got the ARC USB but I'm having trouble with it making my protools slow down and glitch. I think it has something to do with how it's powered (or that my computer isnt fast enough to work with it)
I tried running it directly into one of the two usb 2.0 ports on my 2011 macbook. I also tried it into my (unpowered) USB hub neither work without glitching my Protools session.
I run USB out of my Fireface UFX into the hub with no problem.
I read there was a way to power the ARC via the Fireface but it didnt work going into the front USB port (on UFX)
Does anyone know how I might get this thing to work with my system?, I'd like to keep it. Sure seems useful.
Re: Powering the ARC USB
You might have MIDI problems. Download the SysEx firmware update and activate SysEx mode in TM FX ARC USB Settings.
3 (edited by frednugent 2020-09-17 16:47:52)
Thanks very much MC,
Before I download I should check, is this correct update?
Mac OS X Intel Flash Update Tool ARC USB
2018-10-30
fut_arcusb_mac_v7.zip
Im running OS 10.6.8 with Protools 9.
Correct.
Thanks MC. Will do.
6 (edited by frednugent 2020-09-18 12:47:33)
Hi MC,
Strage. I could not "Flash" the ARC with my recording computer (OS 10.6.8)
I got a pop-up saying "The application requires Mac OS 10.10 or later".
So I took the ARC to my other computer (running OS 10.14) and did the "Flash" there.
The "Flash worked and was updated on the ARC. But when I took it back to my recording computer (10.6.8) I could not see:
"In the lower right beside the Default Encoder Function list the info string 'SE-Mode'
This is not there. I tried to "Flash" again successfully. But still no 'SE-Mode' available. And Protools is slowed beyond working.
Any idea what I should try next?
Thanks.
Any thoughts on how I should proceed?
I have a few more days before I must send it back to Thomann if it's not working with my system.
Any info can help.
8 (edited by ramses 2020-09-21 15:57:28)
Any info can help.
Ask them kindly on phone to extend the period as you have reasons.
9
frednugent wrote:
The "Flash worked and was updated on the ARC. But when I took it back to my recording computer (10.6.8) I could not see:  "In the lower right beside the Default Encoder Function list the info string 'SE-Mode'
Download a newer driver or the latest TotalMix FX that supports this mode. 1.66 is available in this forum.
Thanks MC,
What are the system requirements for TotalMix FX v1.66 + Firmware update, for a Mac?
