1 (edited by amadeusrecords 2020-09-26 09:15:08)
Topic: DUREcorder with Plextor SSD issue
I've bought Plextor Portable SSD 256GB, formatted it with FAT32 Format 1.0.1 utility (as usual), unfortunately my UFX doesn't recognize the file system (FS ERROR). Have any of you met similar problem?
Tomek
Re: DUREcorder with Plextor SSD issue
There could be a small hidden partition on it. Check for that with a tool or OS provided system tool.
According to system tool there was the one partition. I removed it now, created one and performed 32FAT full formatting with the same tool as I usual do. Unfortunately it's not readable by UFX as before :-(
Tomek
Can you select a different partition at the UFX display?
