Topic: Octamic XTC ADAT in routing resets when device is turned off
Is this a known bug? The XTC remembers its MADI routing when turned off, but the ADAT in routing always resets. Thanks
Eastwood Records
www.eastwoodrecords.co.uk
Re: Octamic XTC ADAT in routing resets when device is turned off
Any word from RME on this bug?
Eastwood Records
3
Doesn't happen here. Everything is remembered, ADAT In as well.
Thanks for checking. Is it the same when using MIDI Remote? The XTC is the third MADI unit in the chain in case this matters too.
Eastwood Records
5
Disable MIDI Remote. If it works then try to find out why MIDI Remote resets the Micstasy to 'default' (if so).
I have this as well. If no adat Signal is present at the input when powering the XTC on, the adat routing is lost.
No midi control is necessary to get that behaviour.
Georg
