Topic: ADI-192 DD with multiple inputs of different sample rate
After reading the manual for the ADI-192 DD I'm a bit confused as to it's capabilities.
My hope was that I could feed the ADI-192 DD 4 separate digital inputs, some of which have different sample rates, 1 via the spdif optical port on the front and 3 via AES/EBU on the back. And then re-sample said inputs and send them to a Digiface USB over ADAT, syncing the ADI-192 DD with the Digiface USB via ADAT. But it almost sounds like you have to tell the ADI-192 DD what sample rate the inputs are running at (see highlighted text):
Which has me questioning the ability to resample multiple inputs with different sample rates simultaneously, as it wouldn't appear that the controls give me granularity to set incoming sample rate on each individual input.
