Topic: Reset treble/bass adjustments on power off?
Is it possible for these to zero out once resetting the system?
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → Reset treble/bass adjustments on power off?
3D,
What is your Concern? If you are re-setting the device via Factory Reset, then indeed ALL settings will revert to their Factory Default Settings. ie: B/T =0
I'm confused. Are you worried you'll lose all settings at Power Off time? Easy Answer: No.
Unless you choose otherwise, whatever kooky settings were dialed in last time will STILL be there to Greet You at the next listening. Trust Me! I know this!
Sorry I should have explained further.
I listen to longer music mixes and will sometimes tweak the treble/bass setting. But then I will forget I did that and will keep those settings until I remember I have to zero them out. I usually adjust treble/bass on a per track basis.
However I do shut my system down nightly, so it would be nice if those settings were "forgotten" in case I forgot to zero them out.
nevermind, maybe this is dumb
Not Dumb, and Settings (Last used) are not forgotten.
