1 (edited by esparrow 2020-11-01 22:31:53)
Topic: Microphone volume does not change with loopback
Dear all,
I have a Babyface on a MacBook Pro 2019 with current software (system and drivers).
I would like to stream audio on Doozzoo (a music learning streaming platform) and at the same time record video/audio with Quicktime. I would like that two sound sources are recorded at the same time: my external microphone (connected to AN1) and the sounds generated by the system (including the sounds generated by the video stream). For the other participants of the stream, the the sound coming from my system is supposed to sound normal.
I am working now with a loopback on the hardware output AN 1/2 since both Doozoo and Quicktime do not allow for choosing specific output channels of the Babyface.
If I got it right, in those cases the programs receive the signal of the hardware outputs AN 1/2.
The recording works allright, however, the volume of the microphone does not change if I change the input volume with respect to output channel AN 1/2.
If the external programs get their sound from output AN 1/2, however, the volume of the input channels inclulding the microphone should change if the mix is changed for output channel AN 1/2 - or did I get that wrong?
I would appreciate your help!
Deutsche Version:
Ich habe ein Babyface an einem Macbook Pro 2019 mit aktueller Software (Betriebssystem, RME-Treiber).
Ich würde gern mit Doozzoo Audio streamen und gleichzeitig mit Quicktime Audio aufnehmen, wobei sowohl mein externes Mikrophon (AN1) und die vom Betriebssystem generierten Sounds (einschließlich des Audiostreams) mit aufgenommen werden. Für die anderen Teilnehmer am Stream sollen die Sounds normal klingen.
Ich arbeite nun mit einem Loopback auf dem Hardware Output AN 1/2, da Doozzoo und Quicktime nicht erlauben, einzelne Kanäle auszuwählen.
Wenn ich es recht verstanden habe, erhalten solche Programme das Signal des Hardware Outputs AN 1/2.
Merkwürdigerweise verändert sich die Lautstärke der Mikrophonaufnahme allerdings nicht, wenn ich bei angewähltem Output AN 1/2 die Lautstärke des Mikrofons herunterdrehe.
Wenn aber die externen Programme den Sound von Output AN 1/2 erhalten - warum geht denn dann nicht die Mikrofonlautstärke herunter, wenn man sie leiser mischt?
Vielen Dank für Ihre HIlfe!
