Topic: Expand Babyface Pro FS
How do I get just a few more inputs into the Babyface Pro FS?
I want to run synth stereo tracks into it so no need for preamps, just line ins.
I assume I need an ADAT box. Actually I would be happy with just 2 more inputs so are there any smaller units that does not cost more than the BFP FS itself?
2 (edited by ramses 2020-11-30 12:17:11)
Re: Expand Babyface Pro FS
Yes you can get more analog inputs by connecting an AD or AD/DA converter via ADAT.
ADAT supports 8 channel @44.1/48kHz and 4 channel @88.2/96 kHz and 2 channel @176.4/192 Khz by channel multiplexing.
But are you aware of, that the BBF Pro FS supports already up to 4 analog inputs ?
If you want a very good RME product, then you could take e.g. the ADI-2 FS:
https://www.thomann.de/de/rme_adi_2_fs.htm €685
8 additional channel would be delivered by the ADI-8 DS MKIII
https://www.thomann.de/de/rme_adi8_ds.htm €1466
Alternatively, if you want at the same time an excellend AD/DA converter and phones preamps / USB DAC with advanced features: https://www.thomann.de/de/rme_adi_2_pro … dition.htm €1695
I know it should not be so expensive as you said, I only wanted to give you this overview whats possible.
So the ADI-2 FS sounds like a feasible solution to you.
Additionally it gives you two very nice phones outputs and has a nice compact form factor.
