Topic: raydat sample rates.
Hi, I am currently using my raydat pcie card hooked up to my M-32 DA. Along with a newly purchased focusrite adat clarrett. I have noticed that the Clarett will register sync when using adat in and out. However the M-32 DA does not even register lock. It all works fine. My question is that i recently used the SPDIF oon the raydat to send and return to my Lexicon MPX1 outboard reverb. I noticed the raydat said it was 44.1k and the lexicon is only 44.1k, But everthing else in my setup is 48k. I just wonderd if the raydat can work at both sample rates in master or auto sync. Thanks.
