Topic: Advantages of 56 or 64 channel madi mode ?
I'm using a madi FX with and SSL alphalink AX
The alphalink has 24 analog and 24 adat (3x8) I/O - 48 I/O in total
I' configured this to 56 channel mode - is there any advantage/disadvantage to using 56 or 64 channel mode
It seems 56 channel mode allows a little more +/- on the actual sample frequency (is this an advantage?)
I'm only running at 44.1khz/48khz
