Topic: Digicheck shows red CUV bit in UFX. Does this indicate a defect?
In SR 44.1 KHz mode, in Digichecks "Bit Statistic & Noise" display, all bits are displayed in green despite that last CUV bit, which is permanently displayed in red.
Does this indicate a problem of the UFX+?
Re: Digicheck shows red CUV bit in UFX. Does this indicate a defect?
No.
3 (edited by horstenberg 2020-12-13 17:01:20)
ok. Thanks for your help. Can you explain why this is the case? With my fireface UC in the same situation, the "CUV" Bits are all at a zero-value ("000"). Why are they green and red with the UFX+?
You only see this display on analog inputs 1/2 in USB mode. An analog input obviously does not contain SPDIF/AES Channel Status information. But channels 1/2 include internal USB control information. The UC does the same, but there the information is hidden from DIGICheck.
