Topic: HDSP HDSP(e) driver compatibility
HDSP HDSP(e) driver compatibility? I own the HDSP. Installed the newest HDSP driver. Using Win 10. Driver doesn't appear to work.
Where's the old driver?
RME User Forum → HDSP(e) series → HDSP HDSP(e) driver compatibility
> I own the HDSP.
HDSPe is no product.
This is not a valid information, whats the driver name and what is the version number.
> Using Win 10.
This is insufficiant information, this product exists since around 5y. What version exactly ? 1909, 2004, 20H2 ?
Impossible to be answered as the information, that you gave, is incomplete.
Sorry. I should have been clearer. I have the original (5 years old) HDSP 9632. Not the newer HDSP(e). But that's probably not the issue.
HDSP driver ver 4.29
Win OS Build 19042.685
I get audio from the card, as usual. So I can use it. But no software functionality other than the dsp settings.
Based on this thread it might be the case that your WDM settings have been reset to zero.
Then you have no WDM devices anymore in the Windows Sound Settings.
See also here:
https://forum.rme-audio.de/viewtopic.ph … 63#p153063
While you are at it, please install the "real" latest HDSPe driver, which is 4.36 (not 4.29 as you claimed).
https://rme-audio.de/downloads/driver_hdsp_win_436.zip
Always keep in mind .. if you say "no sound".
On windows there are two main possible audio signal flows
a) through ASIO driver
b) through WDM driver because Windows OS and normal Windows application do not support an ASIO driver.
Once you installed the latest driver, check in the driver settings (win desktop: bottom right: in the Windows notification area)
Number of WDM devices.
Create a WDM device for the I/O port where your monitors are connected to.
Then in the 2nd TAB set it also as speaker device.
Then you get in Windows Sound settings also a speaker device.
This Speaker Device you need to set as Windows default sound device.
I hope that this was the issue and that this will fix your problems.
Thank you.
Rephrased to make it better understandable, please re-read #4.
