Topic: HDSP AES 32 Flash Problems
I've got an RME HDSP AES 32 card that works fine and I'm attempting to flash it back to firmware version 202 for use in a Linux machine. Currently, it will not work in a Linux environment. I got the suggestion from the RME legacy drivers page here:
https://archiv.rme-audio.de/en/download … hive.php#2
Under the HDSP MADI / HDSP AES-32 section, there are 3 files and one is suggested for Linux compatibility. Unfortunately, I can't get the drivers to install on Windows 7 and resorted to this driver that I found on the rme-usa.com site.
This file works:
WDM streaming driver, all HDSP and HDSPe cards/systems 2020-12-09 driver_hdsp_win_436.zip
After confirming that the card works ok in Windows 7, I checked my hardware revision ( 235) and tried to roll back the firmware. Unfortunately, the Flash tool v2.2 HW Rev 202 program wouldn't load and I had to install the card into a Windows XP SP II machine. I got it working with an old 2.40 driver that I found on the Wayback Machine and hoped tried the Rev 202 flash tool again. This time, I got the flash tool working, but I couldn't get past the erasing part.
Scouring the RME fourms led me to this post:
https://forum.rme-audio.de/viewtopic.php?pid=4686#p4686
Re: MADI Word Clock Output not working properly on Linux?
And thanks for the firmware!
Side note: firmware 202 doesn't work with the Windows driver v 2.4 that also is on the archive page.
Version 202 works great with my Linux install though. I wasn't able to update the Alsa-drivers, which would have been the alternative: the system I'm doing this on is a production system.
I did try a newer Alsa version on a different computer. Firmware 203 works with Alsa 1.0.14; I haven't tried any other firmware/Alsa combinations though. Still, HDSPe MADI might work with newer Linux drivers.
My conjecture is that the w2madi_22.zip Windows 2000/XP PnP Hammerfall DSP MADI, Version 2.20 3/06/2004 will allow me to roll back the firmware. Is there any way I can get those drivers? Unfortunately, the Wayback Machine didn't archive the file.
Any help would be appreciated.
