Topic: Direct monitoring issues with cubase
I’m a  very happy user of raydat and cubase. I used to use it connected with an old Steinberg mr816 via adat. Everything was ok, including the DM I always preferred for tracking vocals.
After upgrading my pc with a stronger cpu and having replaced the mr816 with a ferrofish pulse 16 with the same adat connection but adding ch 9-16, DM is not working anymore, with no apparent reason. I checked it all out, as far as my knowledge can reach...
Anyone facing the same problem?
Thank you so much...
2 (edited by ramses 2020-12-24 17:36:04)
Re: Direct monitoring issues with cubase
I read in the forum a year ago or so, that ADM needs HW input channels to be mono and HW outputs to be stereo.
Maybe try TM FX -> Options -> Reset Mix -> "Set inputs mono / outputs stereo (ADM)"
Wouldn't hurt to add relevant information like e.g.:
- HDSPe RayDAT firmware version
- HDSPe driver version
- Cubase version
- Windows Version, if Win 10, then pls add info which release like e.g.: 1909, 2004, 20H2.
3 (edited by maxleoni 2020-12-24 19:41:38)
Thank you Ramses!
Here we are: last updated driver and fw for Raydat, Cubase 11 pro, win 10 last release (system updates automatically)...
I’ll try with your tips..
Thank you
