Topic: Fireface UC ( 0 ) no serial
I just bought a Fireface UC which sounds great when I use analog INPUTS but I can't play any sound coming from my Macbook pro (13" mid 2012 on 10.13.6 OS). I think it might be related to the fact that the soundcard can't recognize itself in my system profiler.
No serial, no vendor...
In my sound preferencies I can see that it's named : Fireface UC Mac (????????)
In Total mix it s named : Fireface UC (0)  instead of the serial number..
Can you help me please ?
Firmware 318
Driver 3.19
Thank you very much.
Best regards,
Pierre Guillaume
Re: Fireface UC ( 0 ) no serial
Firmware 138? Typo?
Did you try to reconnect the unit, and power it off/on to see if the serial number gets recognized?
You can also try to toggle to PC mode and back to AP mode.
If you can reproduce the same issue on a second computer then the UC might be defective.
Thank you for your quick answer !
Yes typo problem : 138 smile
I tried to unplug and replug, switch to AP and PC..
The host light is flashing.. and still no serial recognized... I don't have another computer...
Any idea?
Thank you very much...
Best regards,
Host light flashing points to wrong or defective power supply...
Is it safe to test with a non official power supply ? if yes, which power supply should I use ?
Thank you !
