Topic: [solved]RME UFX II - Distorted analog source through software playback
Hi
I just swapped from UFX to UFX II
Im using the interface for converting and routing signals for a multi way speaker setup
Eight channel of amplification connected to the analog out
Analog source vinyl on analog 1-2
Signal is routed to software that convolutes the signal and send it through software playback
When playing from digital source from computer (jriver or roon) sound is perfect and everything
But when taking signal from analog source, i get a crackeling distorted sound even everything is correctly routed through the convolution software.
I know this is a very untraditional setup of the UFX, but this worked perfectly before using the UFX I, so I don't get it why Im experiencing trouble with analog source using UFX II.
Edit: seems like it was the usb connection that caused the distortion. Moving usb from back to front to a usb3 port on the pc seems to have solved the issue
