Topic: HDSP Aio - update driver from 4.29 to 4.36?
I see there was a new driver published on 9th Dec 2020, version 4.36.  I am currently on 4.29.
Is there anywhere I can check to see what the changes are in order to see if I should update?  (I'm always a bit nervous of fixing something that isn't broke, but then it would be nice to know more so I can balance the risk!)
There was also a flash update dated 2nd Dec 2020.  Is that something I should install also?
Re: HDSP Aio - update driver from 4.29 to 4.36?
If you download the driver file, there is a README text inside with the changelog. There are some bug fixes and an updated TotalMix FX included in the newer driver.
If you decide to update your driver then you also need to flash the current firmware.
Many thanks!
