Topic: RME Babyface Pro FS and Headphone Outs
I understand that you can't do different mixes per headphone out (1/4 & 3.5mm) and that they share the same mix; however, are you able to mute one and leave the other on and vice versa?
Thank you!
Re: RME Babyface Pro FS and Headphone Outs
No as far as I can see you can’t mute one. I have a separate headphone amp so the 1/4” socket I have a pair of headphones connected and 3.5mm I send to my headphone amp and keep the volume down until I need it (I use when I sit at my drum kit)
Thank you.  I might have to end up doing that.  Appreciate the response!
