Topic: Audio errors with fireface 800 on Win10
I am struggling with getting my fireface 800 to work steadily under Windows 10 (fresh installed coming from Windows 8.1 where it worked flawlessly). The fireface settings window is showing an increase of error counts each minute or so. When this happens the audio is stuttering. This is independent of latency buffer sizes or WDM device settings (currently set to 1 WDM device only). When I use the fireface with my laptop running on windows XP it works without any glitches so the unit itself should be ok.
More details:
- Computer specs:
Gigabyte Z87-HDR3 motherboard (onboard video and sound are switched off in the BIOS)
Asus Radeon 6450 HD Silent graphics card
- The following firewire interface cards were tried:
PCI Lacie FireWire 400 card (VIA VT6306 chipset tested in all PCI slots)
PCI-E FireWire controller (VIA 6307L chipset tested in all PCI-e slots)
DAWICONTROL DC-FW800 PCIe controller (Texas Instruments XIO2213B chipset)
- firewire controller drivers (used with the above controller cards)
1394 OHCI Compliant Host Controller (Legacy)
Texas Instruments 1394 OHCI compliant Host controller
VIA 1394 OHCI compliant Host controller
- Multiple firewire cables were tested (both firewire 400 and 800)
- Fireface 800 Driver version 3.125
- Fireface 800 Hardware revision 2.77
Does anyone have some advice? I am running out of options and I would really like to get my fireface 800 working properly under Windows 10. Any help is much appreciated.
