1 (edited by muzicman82 2021-01-22 15:30:09)
Topic: Can a HDSPe MADI FX + TotalMix FX be an actual 390CH Mixer?
Hi all,
I have a client that has a Soundcraft Vi4 with 96 channels of inputs to mix. They are currently sending groups over to a small console for stream/video production, but we are looking for ways of getting all 96 channels available to do a complete separate mix. The Vi4 will have two independent multimode fiber outputs (SC connectors). We're already using one of them with a HDSPe MADI (not FX).
So, two concerns here. First is cost. We're trying to do this as cost effective as possible. Second is space. They currently have a Soundcraft SI Compact 32. That's about the largest a console to replace it can be.
Besides wanting to get all 96 channels over, they want to be able to multitrack it. So, it seems like we may be able to accomplish both with TotalMix FX. I have a few questions...
  • I see that the HDSPe MADI FX can do TotalMix FX with DSP Effects. Do I really get full EQ, Dynamics, etc on every channel the same way I would on a console? Are there limits here? And is there processing on outputs?
  • Can you set up DCAs like a console?
  • What kind of performance can I expect? And what about latency?
  • Can the cue bus be routed anywhere?
  • While I only need a stereo mix for output for program, I could use some analog inputs. I would only be using two optical MADI ports, so I could use an interface on the coax MADI. Can anyone recommend something that has just a few analog inputs and outputs on a single device?
  • OR, can I put a 2nd RME card on the same system to get more analog I/O? I know that in DAW software you have to select one ASIO driver, so I'm not sure how that would work.
EDIT: Another option I was looking at is doing the Fireface UFX+, but I would have to convert one MADI feed from Optical to Coax. I see some advantages to using this interface such as having Analog I/O on the unit, and the unit can multitrack record directly to USB, so my host PC doesn't have to.
EDIT2: UFX+ won't work since it doesn't appear to allow both MADI ports at the same time.
Thanks all!
2 (edited by ramses 2021-01-23 11:33:09)
Re: Can a HDSPe MADI FX + TotalMix FX be an actual 390CH Mixer?
I think I can answer a few of your questions.
Unfortunately, I can't say exactly how many FX effects you can activate in total. But allow me the following observation.
Many years ago, I tried this on a UFX. The result was that you cannot activate FX on all channels. The design certainly includes something like a "mixing calculation". It is very unlikely that anyone needs full FX facilities on all channels. Most of it is done in the DAW or in combination with VSTs anyway. I use a lot of the TM FX functions, but I have only needed EQ in special situations, such as in monitor or headphone mixes, but not on every input. After all, the goal when recording is to record the signals as cleanly and unaltered as possible. So why include an "FX Power2" in devices that would only cause unnecessary costs for almost all users when they buy them?
You could e.g. create Fader groups, AFAIK 4 and a temporary. A DAW like Cubase might be more flexible in that regards allowing for more groups.
Could you kindly be more concrete what you regard as "performance" here ?
You are also very unspecific, which latency you mean. On the card itself, or do you mean round trip latency ?
For what device ? At what sample rate ? With what ASIO buffer settings ?
I can tell you generally, that RME products have excellent drivers and very low latencies. No matter whether on the device itself (near zero latency monitoring ) or through USB or PCIe.
See here the RTL of different RME products which I had access to.
https://www.tonstudio-forum.de/index.php/Attachment/2343-UFX-UFX-RayDAT-Latencies-v2-jpg/
You have a low latency CUE and PFL function in TM FX. You can assign it to one of the outputs in the TM FX control room (Main Out, Phones 1 ... Phones 4) using the assign button.
Inputs and SW Playback channels can be set to have either Solo or PFL function via TM FX -> Options -> Settings.
HW Output can use Cue.
According to the manual the WC ports can be used for MADI coax in two modes
- coax being a mirror of optical MADI port
- split 32ch optical / 32ch coax
But at the end of the day the UFX+ has only one MADI bus. This allows for 64ch at single speed and 32ch at double speed.
The question is whether this is sufficient or not.
Do you mean a recording interface or an ADAT or MADI based external device ?
It would be helpful if you could sum up your minimum requirements.
What sample rates are you using ? Single, Double, Quad ?
How many MADI channels do you need of what type ?
How many analog inputs and outputs do you need ? On the device itself or via ADAT/MADI extension ?
1st of all, when using multiple cards then you need to synchronize them either by WC or by using 1 digital connection between them, e.g. on the clock master one adat TOSLIN to the next cards input and this card can read then the clock from this input. You need manually ensure in the RME driver settings, that all cards are using the same ASIO buffer size.
You will get a TotalMix FX instance per recording interface and on TotalMix FX level you can not route channels between those interfaces only inside of such an instance.
If you perform routing on DAW Level then this is no issue, because if you use two or three cards of the same kind, then you can access them all through the same ASIO driver.
Caveat: RME drivers usually support up to 3 cards of the same type, but there can be certain limitations on the computer side whether the system can work with so many cards and channels and this also depends on the sample rates being used.
I think one of the best cards is the HDSPe MADI FX, because
- its the only PCIe card with full implmentation of FX chip
- the card has a unique performance optimizing driver, groups all channels in groups of 8 and if no channel in such a group is being used, then the driver does not allocate resources for all of these 8 channels. So if you organize the connections properly and use maybe only half of them, then only 50% of the channels are being transferred instantly over PCIe not the whole amount of channels. And if you only use 2 channels in a project, then the resource consumption is only minimal. This is one of the best performance saving drivers.
- it has additional analog phones outputs, so that you can directly monitor using phones (very nice and flexible)
- it has AES I/O You could e.g. very nicely connect an ADI-2 Pro R BE to have a very nice phones preamps as well as best features for monitors and additionally also high quality analog inputs.
- if offers 3 MADI busses, 2 optical, 1 coaxial and the coaxial can also be replaced by a different daughter card so that you can have even three optical MADI busses
- offers MADI routing and Redundancy features
You can look here at my review of the HDSPe MADI FX:
https://www.tonstudio-forum.de/blog/ind … Pro-FS-BE/
The full review in PDF format:
https://www.tonstudio-forum.de/index.ph … -v1-1-pdf/
3 (edited by ramses 2021-01-23 12:42:25)
Another possibility might be to use the MADI integration features of AVB devices, check this out with a RME to get a confirmation, but then no FX effects.
Look to this diagram from my 12Mic blog article 1st:
https://www.tonstudio-forum.de/blog/ind … XTC-DE-EN/
https://www.tonstudio-forum.de/index.php/Attachment/2648-03-Use-Cases-jpg/
And now look at the new RME device "AVB Tool".
https://www.rme-audio.de/de_avb-tool.html
"The RME AVB Tool combines MADI and deterministic AVB networked audio with four high-precision microphone, instrument and line level inputs, plus headphone and separate line level outputs. Following RME’s concept of maximum versatility and connectivity, 128 channels of MADI I/O have been also added to this half rack 19” device."
So you could create e.g. such a setup:
MADI = 64ch @single speed, 32ch @double speed ...
Am not so familiar with the Soundcraft and its madi modules / connections, but lets assume it has 2 optical MADI busses
Digiface AVB ---- AVB Switch +--- AVB Tool +---- MADI optical -------  Soundcraft Vi4
                                             |                    +---- MADI coaxial
                                             +--- AVB Tool +---- MADI optical------    Soundcraft Vi4
        +---- MADI coaxial
Additionally the AVB tool gives you some inputs and outputs
If you need more inputs and outputs and maybe even Mic inputs then use this combination:
Digiface AVB ---- AVB Switch +--- 12Mic          +---- MADI optical (SFP) -------  Soundcraft Vi4
                                             |          + 12 Mic Inputs, can also be used as line inputs, 1-4 as Instr Input
                                             |          + 3 ADAT OUTPUTS, can also be used as format converter
                                             |          + 2x analog out (as phones output)
                                             +--- M-1610 Pro +--- MADI optical (SFP) ------    Soundcraft Vi4
                                                        + AD/DA converter, reference level configurable per port
                                                        + 4 x ADAT OUTPUTS, can also be used as format converter
Check together with RME, which setup offers to you best benefits.
The high technical efforts behind AVB should make possible in these AVB setups, that audio from your Mix console through the two different AVB devices should arrive at the same time at your Digiface AVB.
As far as I understood this is only possible with AVB even through the whole AVB network and with MADI on one MADI bus when using delay compensation, if the devices support this (need to be 8ch devices like e.g. XTC).
Interesting thought. I'm familiar with AVB. The switches required for it might make it expensive. Dante would be easier to do but not having FX would defeat the purpose of this sort of application.
Good points here.. most of which point to the fact that TotalMix can't do what I need. It seems like it isn't very clear what it's limitations are. To replace a digital console, it would need to support full dynamics and EQ on every input and output. Being only able to apply "some" effects would be a problem. With a lot of new DSP platforms, the roundtrip latency and processing is exactly the same whether you engage 1x compressor or 64x compressors. I was hoping this was the case with the FX processing here. I'd like to know more about what the limits are but I can't find much.
6 (edited by ramses 2021-01-25 16:49:18)
One unique point for AVB vs Dante is, that the timing in AVB is more precise compared to Dante.
Its compareable to the RME MADI feature of delay compensation.
Its from the times when people bought a MADI chain of up to 8 devices.
Delay compensation made it possible to connect the two mics for stereo microphony to any of the 8 Mic Preamps of the MADI chain, ie Left channel to 1st device and Right channel to last device in the chain and still the L/R audio signal arrived sample correct in the DAW.
I heard the same is achieveable with AVB, but not not (or not so easy) with Dante. I would ask RME on this topic.
