Topic: Setup challenges. Streamer->Dac>Amp
Hi! I just started listening to music again after 25 years of absence. Got a Node2i streamer with Tidal&Qubuz into a Rme dac2fs into a Bryston 4bst amp I to a pair of Dynaudio Contour 3.3 and a pair of Dynaudio Craffts. I’ve got some questions perhaps I’ll find answers here :-).
1. The sound from my speakers when listening to vocal and songs with single instruments is very good. But with added instruments etc the music feel clogged and not clear. What could be the reasons for this?
2. To really fill the room with music I often find myself needing to turn the Dac down to -30db or even lower. Is this normal/good/ok?
3. My cables into the Dac are both optical and coax and despite common sense logic, i can hear a difference, how can that be. Both cables are not high end but just quality stuff.
4. Instead of the Bryston, I also have two pairs of T+A A 1200R amps which are setup as monos, would they better for the Dac and overall quality of the music (I understand that I need to test myself but perhaps there is an obvious answers). I connected them briefly and it seems that the volume does not need to be so high on the Dac to get the same listening volume.
5. Are there any basic settings I should undertake on the Dac to optimise the sound from the beginning? I just plugged it all in and have not touched the manual.
Thanks in advance.
M
2 (edited by KaiS 2021-02-03 14:25:44)
Re: Setup challenges. Streamer->Dac>Amp
What listening level?
Which of the above mentioned speakers?
Do you change volume level between running the various styles?
Maybe ADI-2’s “Loudness”-function can help:
• Switch on Loudness.
• Set lower reference level 20 dB below your normal listening level for small ensembles.
See here, Case2:
https://forum.rme-audio.de/viewtopic.ph … 21#p161721
Optical and Coax are equivalent.
For distances up to 5-10 m cable quality doesn’t make a difference in the sound.
If the cable quality is insufficient you get unmistakable audible drop outs.
Maybe SRC (Sample Rate Converter) is active on one of the two.
Or there are different settings in Node2i?
Run RME BitTest.
RTFM, really! smile
Let run Norah Jones, get a glass of wine and read it all through, once - please!
Try settings, take notes.
You won’t understand our advice without.
The first thing I would look into is room acoustics - how lively is the room?
4 (edited by ramses 2021-02-04 06:35:05)
According to wizard's post #1 he uses ADI-2 DAC FS which has no SRC.
EDIT: before I forget, not long ago somebody gave me a good tip wink
https://forum.rme-audio.de/viewtopic.ph … 71#p164771
