Topic: Fireface UCX - USB connection problem
if I de-connect my Fireface from my MacBook Pro and want to re-connect it, I always need to unplug and plug in the USB Cable at my Fireface. Otherwise my Macbook doesn't detect the interface - which is very annoying because it's not that easy to reach the backside of my Fireface and I can't see anything there.
(Switching the interface off and on again has the same effect by the way - but if I have my pair of monitors turned on, I would have to turn them off beforehand - which would be even one step more)
Does someone know that problem?
Or do I need to live with that?
Thank you in advance,
Max
PS.:
Just to be clear, it works totally fine and if I turn the computer on and  t h e n  my Fireface, there is no problem. But sometimes I use my Fireface in stand-alone mode for my epiano or something
Re: Fireface UCX - USB connection problem
Known Apple behaviour. Do you use the latest firmware for the UCX, v48 - 260?
