Topic: Multfiace standalone works! Disconnect mode - host light blinking
Hey guys is this normal?  I'm using my multiface as a standalone converter.  I got power going to it (though I don't think it's the original power supply and doesn't seem to match the spec from what I've been reading in forums - Input: 50/60hz 0.6A.  Output: 12V/2A.)  It works.  I get signal coming in and out of it but when I select "Disconnect" from settings and turn off the PC, the host light blinks.  I get it that it lost connection to the host but I'm in disconnect mode and it's working fine as a standalone converter.  So is the host light supposed to be blinking?  Maybe I'm not supplying the multiface with the correct power?
Re: Multfiace standalone works! Disconnect mode - host light blinking
If I remember this correct, yes the light is blinking because it has to.
No connection to the computer, light does blinking.
