Totalmix menu Option / Mix Reset / Total Reset
Do a total reset first.
Then the mic input channel with your voice : there is a little send fader, push it up.
Activate reverb as you like it. At the moment you can't hear the reverb adjust it later.
Click the main output channel for activat it (highlight it)
Doubleclick on the fader of the mic input channel and also doubleclick on the first from left side software playback channel (middle row, karaoke to main out)
The main out channel has a little fader, the fx return, push it up for having reverb on the voice.
Push up the fader of the main out for listening the karaoke with your voice covered in reverb. Now you can adjust the reverb.
Of course it is not possible to listen the karaoke free of reverb on the same speakers and the reverbered voice in the same time as it is mixed all together. But the reverb is made of your voice only. You stop singing and the reverb will go away.
