Topic: Trying to sync an Octa Mic II
I was trying to synchronise an OctaMic II to our UFX II by connecting the UFX II's Wordclock Out to the Octa Mic's Wordclock In. I followed all procedures as described in the Manual and set the little jumpers on the OctaMic accordingly to follow the Clock.
The corresponding ADAT LED is always blinking, the Input Status in the Fireface USB Settings is jumping between Sync and Lock and the OctaMic is not following Sample Rate changes done on the UFX II. All other connected ADAT devices receive their clock via ADAT, they are always synchronising fine.
We tried all jumper settings, with and without wordclock termination. Any hints?
The only way it stays in sync is when I set the Clockmode of the UFX II to ADAT 1 which makes the OctaMic the Clock Source. This also works when the OctaMic's jumpers are switched to "EXT". Is maybe the jumper broken or is it expected behaviour that the OctaMic II is still emitting a Clock Signal via ADAT when set on "EXT"?
Having the OctaMic II as the Clock Source is inconvenient when it comes to changing the Sample Rate (need to to this with a little screwdriver at the back of the OctaMic...). This is why I would like the UFX II to be the Main Device.
In case it matters, here are all the ADAT connection on the UFX II:
ADAT IN 1: OctaMic II
ADAT OUT 1: Fireface 800 in standalone mode
ADAT IN 2: Fireface 800 in standalone mode
ADAT OUT 2: Behringer ADA 8000
