Topic: Direct out of Fireface UFX
Hi Guys,
I recently ran into a silly problem and cant seem to find the answer.
I'm running channels 3-8 direct lines out of my Fireface UFX into a Tascam 388 machine (1+2 are my speakers).
Trying to go 6 tracks to tape and back.
Everything on 388 is patched and set correctly.
In Protools I have each track output set to corresponding hardware outs. All cables are correct and double checked.
My problem is I'm not getting each track to output only that sound.
I'm getting some of output 4 (vocals) in track 7 (guitar) on the 388, etc.
I cant seem to seperate the outputs correctly.
In Total Mix I'm getting signal on stereo 3+4, 5+6, 7+8. I tried breaking them down to mono on the "hardware outputs" in Total Mix but still have the same problem.
Any idea how to simply go out the correct output of the UFX with the sound routed for that output only?
Thanks,
Fred
