Topic: Feature Request
I would like to have my output channel saved as well within the snap shots.  For example if I create a snap shot I with monitors on and headphones off I would like the output to automatically link to that  channel. On snapshot 2 I have a headphone mix, so it would be nice if the output channel automatically switched to the phones mix so that I can automatically turn the volume down with the jog wheel.
Also if we could control the command other functions with a double tap.  For example Double tap Dim could mute.
Double tap A could turn on Phantom Power, etc.
Yes the ARC usb is a better device to control these funcions... But I think the Babyface Pro could do a lot more than it currently does
Thanks!
RME Babyface Pro, Mac Mini M1 Big sur latest
2 (edited by ramses 2021-04-02 11:34:49)
Re: Feature Request
Not sure whether I understand your request correctly and I have to admit, it is a bit hard to understand.
1st of all I think this is related to this thread, right ?! https://forum.rme-audio.de/viewtopic.ph … 71#p168371
You have now a fader group between monitors and phones...
Mute Phones .. save to snapshot 1
Unmute Phones, mute Monitors .. save to snapshot 2
Recall snapshot 1 ... Phones are muted, sound is being send only to monitors
Recall snapshot 2 ... Monitors are muted, sound is being send only to phones
If I understood your request correctly, then it's exactly what you want.
If not .. then please try to make the description better understandable, many thanks.
Re: Feature Request
Have the outputs on the rme babyface be linked.  You know there are three output options.  CH 1/2, Phones, OPT
I think it should follow whatever the mix is.  If headphones are the main outs then the output should automatically switch from CH 1/2 to phones.  Does that make sense?  Hard to describe I suppose, without a video
Re: Feature Request
In every TM snapshot you can assign another HW output as "Main Out".
Is maybe that not known by you ?
5
Re: Feature Request
He wants the jog wheel to automatically control the Main Out that is selected in the specific Snapshot. That will not happen for various reasons, sorry.
