Topic: Transmit audio from a second computer to the rme fireface uc-jack 3.5
I use a fixed computer connected via usb to the rme fireface uc, it is possible to transmit the audio from a second computer (laptop) through its headphone output and entering the sound card in the balanced line inputs on the back (5-6) (7-8 ) .using this cable.Thank you
(it would be very convenient and quick to make a computer that is not mine hear the audio without the need to install the drivers and unplug the usb).
https://www.thomann.de/it/cordial_cfy_3 … D0EALw_wcB
Re: Transmit audio from a second computer to the rme fireface uc-jack 3.5
Yes no problem. Analog audio can interconnect everywhere.
Use Totalmix for routing the incoming signal to the desired output, headphones or speakers.
