1 (edited by bbowersox42 2021-04-17 21:26:27)
Topic: [Solved] Babyface Pro FS jog wheel not adjusting inputs
So I just got my Babyface Pro FS last week.
The jog wheel is not adjusting anything when I select the "in" button, neither CH1/2 or CH3/4. It works fine when I select the "out" button for controlling the A/N output.
I'm new to totalmix. Am I doing something wrong?
Re: [Solved] Babyface Pro FS jog wheel not adjusting inputs
May you check the firmware ?
The USB Fireface settings dialog shows the version actual loaded.
Or you just download the latest flash tool for your computer.
As you are new to Totalmix you may not had enough time to mess up so much.
But in any case you can perform a total reset.
in Totalmix menu Option reset Options total reset.
Do you have a signal connected to an input ?
You are not doing wrong, press the In button to select the input and adjust the gain with the jog wheel.
It should work.
Thanks for the response waedi.
I'm on the newest (130). I did download and run the latest flash
I tried doing the total reset and it didn't help the issue. I have used it on my Windows 10 PC and an iPad and I get signal fine but I have to adjust the gain with my mouse in TotalMix.
Pressing the "in" button allows me to toggle between the different inputs but jog wheel does nothing for inputs. When I press "out" I can select the different outputs and the jog wheel works properly for each of those outputs. It controls them in TotalMix.
Disregard. I didn't realize you had to hit the select key to pick which input you want to change the gain for.
