Topic: HDSPe MADI into M1610-Pro: auto samplerate switching possible?
Hope some MADI experienced people can help.
How do I set up my M1610-Pro to auto switch to the RME MADI's current sample rate?
I have tried the following set up
A. Clock on the 1610 set to 48, MADI card set as master
MADI card set at 44.1: M-1610 will upsample to 48. Warning light appears on power button
MADI card set at 48: works as expected
MADI card set at 88.2: M-1610 will upsample to 96. Warning light appears on power button
MADI card set at 96: M-1610 works as expected
B. Clock on the 1610 set to 96kHz, MADI card set as master
MADI card set at 44.1: M-1610 won't sync at all. Warning light appears on power button
MADI card set at 48: M-1610 won't sync at all. Warning light appears on power button
MADI card set at 88.2: M-1610 will upsample to 96kHz and display a red flashing warning light on the power button
But I would like to be able to have the M1610 auto switch to any sample rate between 44.1 and 96kHz without upsampling and without warning lights flashing, if poss.
I'm new to MADI (coming from AES), so any help greatfully received.
Douglas.
