1 (edited by clintbraswell 2021-05-06 11:25:29)
Topic: trying to connect TotalMix App to host DAW
I came across an RME video showing how to connect the TotalMix remote app to the host computer.  I enabled " Total Mix Remove Server" as instructed. But the next step is my problem. It says to enter the hosts information on the ipad.
It says to go into "Host Connection Settings" under the app's setting. But I don't have the option listed.  So I have no way to enter the host's information into the app.  I've updated the UFX Drivers.  What am I missing?
Thanks!!
Clint
UPDATE:  I just found out what my problem was. I didn't know there were 2 different apps.  I saw this in a separate post. I was trying to connect to the TotalMix App instead of the TotalMix Remote App.  It's working like a charm now!
Re: trying to connect TotalMix App to host DAW
There are two apps for the iPad.
Totalmix FX, to be used when using the interface in Class compliant mode directly connected to your iPad via USB (+Lightning to USB adapter)
And
Totalmix Remote, to be used to remotely control TMFX running on your host computer.
Are you sure you’re trying with the latter?
