Topic: Snapshot 1 not storing my 'Main' fader level
Hi all,
I'm learning the TotalMix software, and have gotten my head (nearly) around sotring and recalling Snapshots. However, I've got a bit of a problem with the 'Main' level in snapshot one. It reverts to -∞ every time snapshot 1 is recalled. It's fine on all other snapshots. I realise this isn't a lot of info to go on, I just wondered whether it was a known bug before I go nuts with more user-error checking.
It's not a showstopper, I can just switch between Snapshots 2&3 (I've set up a simple system for recording vs monitoring for now)
but it would be good to know if this is a known issue.
Thanks so much
Mike
Re: Snapshot 1 not storing my 'Main' fader level
Options - Preferences - Do not load - is set to what?
Do not load is set to Main Volume. What a nifty little setting! Thank you kindly
