damascato79 wrote:I bought my unit just at the end of February from a reputable shop here in Sydney.
I now read around that there is an older version and a newer with AK4493 chip.
Is there any way to check what version is mine?
Hi Damascato,
see this sticky article for an overview of the ADI-2 DAC / Pro devices in order of appearance and their differences:
https://forum.rme-audio.de/viewtopic.ph … 06#p165706
If you are not yet familiar with the operation of your new device, here is how to find this out, e.g. for "Main Out 1/2":
I/O -> Main Out 1/2 -> Settings -> DA Filter -> SD LD
Hint: while you are at it, you can check the current filter settings for all ports by turning Encoder 1 "B".
More verbose instructions:
Press Button I/O
Turn Encoder 1 "B" until you see "Main Output 1/2" in the 1st line of the display (green background)
Turn Encoder 2 "T" until you see "Settings" in the 2nd line of the display (grey background)
Push Encoder 2 to scroll down on this menue page until you are on the entry "D/A Filter"
[ push Encoder 1 to scroll up, if you missed the enty ]
At the entry "D/A" Filter turn Encoder 2 clock-wise to the last entry which should be "SD LD".
For more information about the D/A filter "SD LD", see manual p. 83.
https://www.rme-audio.de/download/adi2dacr_d.pdf
https://www.rme-audio.de/download/adi2dacr_e.pdf
