Topic: Fireface 802: ADM with Cubase 11
I just get my new 802 and I have some problem.
The 802 is plugged via USB, my OS is Win 10 20H2.
I'm trying to use ADM with Cubase 11.0.20. I state that:
- I have activated Asio Direct Monitoring on Cubase
- I am using TotalMix in DAW mode (loaded BEFORE Cubase)
- I reset the mixer with the DAW preset (all mono inputs and all stereo outputs)
- "Disable ASio Direct Monitoring" is NOT checked in preferences
- I'm using very last firmware and drivers
When I activate monitoring on Cubase channel (orange speaker button) with a microphone plugged in, the meter moves, but I can't get the sound anywhere. In particular, if any CUE send is active in the active track, it will not work, regardless of which output I connected the Cue send from Cubase to. No issue with my previous soundcard (MOTU Hybrid MK2, which I changed for the Fireface).
What can I try to do? I made a screen with the situation in Cubase and TotalMix.
Thank you in advance for your suggestions.
