Topic: Extract fader value?
Hello there, I got an odd request.
Is it some how possible to "extract" a specific fader value so that this can be shows in a separate window on the computer? Meaning the same computer that the RME card is installed in.
Hope that makes sense?
//M
2 (edited by gl 2021-05-27 22:29:37)
Re: Extract fader value?
you could read the MIDI (or OSC) values TotalMix sends out as part of its control surface support.  It supports the Mackie protocol (and maybe more, I haven't looked too closely but I do use it with a Mackie-compatible surface).
TotalMix sends out the value of any changes, so that the surface can reflect them.  For example, if you move a slider in TotalMix, a connected control surface needs to know too, so TotalMix sends out the values as they change.  You may need to enable surface protocol support in the settings, but I don't think you need a surface actually connected to receive the values via MIDI.
Or you could use a software control surface emulation program, then it should all just work.
Good idea, like On-Screen-Display.
