Topic: Better DSP EQ (broader settings, more advanced features needed)
Sup folks, I can't find it in the search so here's an official suggestions thread from yours truly.
The 3 band DSP EQ needs to be revamped. I suggest:
Extend the Q/slope further than 0.7-5.0
Extend the amount of dynamics (more than the current -20 - +20db)
Ability to change all and any of the 3 bands type to any of the 3 available options (so all 3 buttons can do low shelf, high shelf, or notch)
Ability to change the middle eq band to any/all of the 3 options available for the first and third eq band
Basically, so all 3 EQ bands can do any of the 3 EQ types, so you can do proper shelving out of all high frequencies, as it is now, the current limiting settings cannot do that.
Bonus tip: Ability to change the LC button to a HC (high cut) - same options for HZ & DB/octav just reversed so from 500hz-20khz
