Topic: How to isolate audio output to just headphones?
Hello
I have my FireFace UFX with total mix which i am relatively new to.
I am trying to understand how to have the audio only come out of the headphones or only come out of the speakers depending on which one I want in windows 10.
Currently if I select from windows the headphones as the main output, I get both sound from the headphones and the main speakers. But if i select the speakers in windows 10 then that seems to work correctly.
Here is a some pictures to explain better.
This is my setup for the speakers channel:
Now if i select the headphones:
You can see here i still have audio coming out of the main speakers, how do I set it up so it will only come out of the headphones when i change the default audio output in windows 10 ?
Hope you can help.
