Topic: Ref Level to Musical Fidelity A3.2
Hello everyone!
I am a new owner of the ADI-2 DAC FS and I need help choosing the optimal settings for my system. I looked through a few threads about Ref Level, but I don't fully understand how to convert dBu values. My configuration is ADI-2 DAC FS + Musical Fidelity A3.2 + KEF R300. I found the following information about the amp in the manual:
Power output at 1kHz for 0.5% distortion: 115 Watts per channel into 8 ohms
Total harmonic distortion 1kHz: < 0.007%
Frequency response 10Hz to 20kHz ± 0.3dB
Channel separation: > 85dB 20Hz to 20kHz
Input sensitivity line inputs: 300mV, 200k ohms
phono input MM 3.5mV, 47k ohms
phono input MC 350µV, 47k ohms
Signal / noise ratio line inputs: > 103dB ‘A’-weighted,
(ref.120 Watts, 8 ohms ) > 95dB unweighted
phono MM: > 96dB ‘A’-weighted
> 89dB unweghted
phono MC: > 88dB ‘A’-weighted
> 82dB unweighted
What should the settings be like in such a case?
• Reference level:?
• Auto Reference Level on / off?
