Topic: Driver update to 1212 mute TotalMix FX after resume standby on W10
I recently update my Babyface driver from 1167 to 1212. Now, always after I resume from standby unter W10 I have to touch the slider for software playback to have output on the master (level meter of master show no signal until I touch the slider of software playback channel). Meaning, the last setting before standby is not available/setup.
With thís update TotalMix Fx the version change as well from 1.60 to 1.73.
I am uncertain if this issue is a TotalMix Fx issue or a driver issue, but as I can fix it by touch the slider it may belong to TotalMix FX.
What I try to get rid of the issue:
- Reset TotalMix FX completly
- Try some settings from TotalMix FX (init..,), nothing helps
- Store setting as snapshot does not help even (click to restore help not. I have to move the slider)
- Instead Standby, Reboot , yes, this works
- Reinstall old driver 1167, yes, now resume from standby provide again the last setting
Maybe I have overseen something and this is a feature from 1167 to 1212?
I really like the old behaviour back.
Any help welcome.
Sascha
Re: Driver update to 1212 mute TotalMix FX after resume standby on W10
If it would be helpful I can check versions in between 1167 to 1212. Or is this behaviour known?
3
We are investigating this effect right now. Please wait what we find.
https://forum.rme-audio.de/viewtopic.ph … 87#p173087
5 (edited by sas 2021-07-09 12:45:09)
Works now. Thank you very much for the quick fix. Great!
