Topic: Feature Request: output level in dBu/Veff after tone control, PEQ, ...
What do you think of the following idea for the ADI-2 DAC / Pro.
Another display mode for displaying the output level
- in dBu as chosen with the volume poti and
- in dBu and Veff after after tone controls (B/T, PEQ, dynamic loudness).
For ADI-2 DAC additionally the 6dB lower level at the cinch outputs.
In my opinion, that would make it a lot easier to adjust the level and to find the optimal setting for both devices more quickly.
From the analog input of the connected device (preamplifier or integrated amplifier) you either know the maximum input level from the data sheets (or you ask the manufacturer) or you simply orientate yourself on known / defined variables such as consumer or different studio levels. An additional "safety buffer" can be selected according to personal taste/experience.
With this new display, you could find the optimal volume setting on the ADI more quickly if the resulting values for the output level were displayed.
Autoreflevel seems to already be doing such calculations internally. Example: if you set a volume value shortly before switching to the next higher reflect level, then a treble or bass boost with the B / T controller by 0.5 dB causes a change to the next reflect level, because this gives the signal a higher level. Same effect with changes by PEQ and dynamic loudness.
%--------------- auf Deutsch -----------------------------------------------------
Was haltet Ihr von der folgenden Idee für den ADI-2 DAC/Pro ?!
Ein weiterer Anzeigemodus zur Anzeige des Ausgangspegels
- in dBu wie mit dem Volume Poti eingestellt und
- in dBu und Veff nach der Klangregelung (B/T, PEQ, dynamische Loudness).
Bei ADI-2 DAC zusätzlich noch die um 6dB niedrigeren Pegel an den Cinch-Ausgängen.
Das würde es meiner Meinung nach viel einfacher machen, den Pegel anzupassen und schneller die optimale Einstellung für beide Geräte zu finden.
Vom analogen Eingang des angeschlossenen Gerätes (Vorverstärker oder Vollverstärker) kennt man entweder den maximalen Eingangspegel aus den Datenblättern (oder man fragt beim Hersteller nach) oder man orientiert sich einfach an bekannten/definierten Größen wie Consumer- oder anderen Studio Reference Levels. Einen zusätzlichen "Sicherheitspuffer" kann man nach persönlichem Gusto / eigenen Erfahrungen wählen.
Mit diesem neuen Display könnte man somit die optimale Lautstärkeeinstellung am ADI schneller finden, wenn die resultierenden Werte für den Ausgangspegel angezeigt würden.
Autoreflevel scheint solche Berechnungen bereits intern durchzuführen. Beispiel: Wenn Sie kurz vor dem Umschalten auf den nächsthöheren Reflect-Pegel einen Lautstärkewert einstellen, dann bewirkt eine Höhen- oder Bassanhebung mit dem B/T-Regler um 0,5 dB einen Wechsel auf den nächsten Reflect-Pegel, denn dadurch erhält das Signal einen höheren Pegel . Gleicher Effekt mit Änderungen von PEQ und dynamischer Lautstärke.
