Topic: Setup Not Saving Sample Rate?
I’m having a small issue with my ADI-2 Pro FS B where I save a setup and it’s meant to save the current sample rate right? Well for some reason it’s not. I want the saved sample rate to be 96Khz. I really only use 2 setups. One for monitoring digital in to analog out and the other for analog in to analog out.
When I switch to setup 3 the sample rate goes to 192Khz even though I have saved several times at 96Khz. I go to setup 2 and sample rate correctly switches back to 96Khz.
Any thoughts?
__________________________
Paul Najar
Jaminajar Music Production
www.jaminajar.com
