Topic: MacOS/ Apple music streaming questions
Hello RME engineers, Hello fellow members,
I ordered the ADI-2 DAC and its on the way, not yet arrived, but I read the pdf manual already.
I have few questions and wish someone can shed some light on me.
I am using Mac Mini intel running Big Sur, you know MacOS Audio Midi can set up sample rate from 44.1 up to 768kHz.
So the first question is, if I play back (stream) an album (Apple Music) with songs some are 96kHz, some 192kHz, what setting should I set at the Audio Midi? is the highest one can downwards support lower sample rate songs without causing any distortion or error? and for example if I set at 384kHz and play a 192kHz song, what rate will display at the ADI-2 DAC?
Second question is, if I connect the RCA jack to an Amp, is the XLR will automatically off? and vice versa?
Third question, I do not quite understand about the recording function, or could be I misunderstood it at all..... is the USB can output signal for recording while the S/PDIF connected to a source?
Thanks in advance and waiting for answers for me (a novice of RME technology) .....
