Topic: Babyface standalone mode: Channel 3 or 4 to Left _AND_ Right Headphone
Can I mix an input channel (say 4) to be heard mono on the left and right headphone output when I'm in standalone mode? Haven't found a way to achieve that. Or is that ruled out due "no panorama function" in stand-alone-mode? :-(
Re: Babyface standalone mode: Channel 3 or 4 to Left _AND_ Right Headphone
Yes ruled out.
You can use a Y-adapter cable to provide your signal to both inputs.
Thanks for the answer. Too bad that I can not assign a Mono-function in the standalone-mode. Would not need full blown panorama settings, just Mono...
