Topic: [AW] Recording fwith JRiver or Audacity
Hello
I want to record the phone preamp output on file, using an ADI2PRO.
I use a 64 bit W10 JRiver 28 as DAW and I tried to use mrecordier, a free-of-charge VST plug which does not work well ...
- question 1: can somebody recommend a 64bit cheap or free VST plugin for recording?
I then tried Audacity and I can record using Analog (1+2) RME ADI2 PRO recording device (Audacity does not support ASIO for licensing issue). Sampling frequency cannot be greater than 48 KHz in audacity but RME can sample at greater FS (actually it is set to 96KHz): how does all of this work? Did anybody use Audacy +ADI2PRO for recording and suggest me a safe setting?
Thanks much
Server: JRiver 30+Dirac+Acon Declick
DAC: RME ADI2 PRO Speakers ATC SCM50ASL
