Topic: ADI-2 Pro FS R BE multichannel analog output question
Hi very much a newb question.
I'm running an active hifi system then needs two stereo channels (ie four channels of input into my amps).
If I send four channels of digital into an ADI-2 Pro FS R BE can it output four channels of analog?
The manual states: "The ADI-2 Pro is a 2-channel analog input to digital and 4-channel digital to analog output "
It's not clear (to me anyway) from the manual whether the 4 outputs labelled as Main outputs 1/2 (2xTRS and 2X XLR) are independent
thanks in advance!
2 (edited by rawac 2021-07-18 18:04:51)
Re: ADI-2 Pro FS R BE multichannel analog output question
Please look at the diagram >ADI-2 Pro USB Mode 6/8 channels< in the manual. In version 3.3 it's page 40. The connections between outputs XLR, TR and PH is fix to the upper DAC, channel 1/2. Only PH 3/4 is connected with the lower DAC, channel 3/4. If you need 4 analog outputs you have to use PH 3/4 for channel 3 and 4. As you see in the other diagrams, these connections do not depend on the mode.
Ralf
(ADI-2 Pro FS with ThinkPad Yoga L13, Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
Thanks for the reply.
That's a bit of a messy solution unfortunately sad
Does there exist an RME device that has similar functionality - analog and digital inputs and four or more channels of analog-out with remote control and loudness and parametric EQ?
4 (edited by KaiS 2021-07-19 06:55:47)
Not exactly, no remote and Loudness function anywhere.
Even no such powerfull headphones outputs.
You can use an angled plug in PH 3/4, running the cable down, below ADI-2 Pro.
Then it doesn‘t look messy.
In my studio I had to do this with rack mount devices that unfortunately have their connection on the front panel.
