Topic: Babyface Pro FS switch from unhappy Arturia Audiofuse User?
HelloHello,
i am new to this forum....
since i´m very unhappy with the arturia audiofuse (terrible build quality, extremly hot, broken knobs etc..)
i consider updating to a Babyface Pro FS ..but i have many questions. hope somebody can help me out with answers:
1) as i am "in the box" musician i only need half of the potential the audiofuse uses, but i need
a prestine audio output. Will the babyface pro FS give me the same clarity and detail on my (Neumann KH120) speaker?
2) biggest problem that keeps me from switching is, that i need a second pair of speakers connected, but the Babyface only
has 2 XLR outputs. Since my second speakers are only a pair of "grotspeakers" (active Avantones) my Idea ist, to connect
the second speakerpair through one of the headphone outputs. will that work?
Also, will the main speaker-output automatically muted, if i plug-in something into the headphone jack, or can i switch the
outputs and customize them with a button?
3) *if* its possible to enable/disable and switch speakeroutput/headphone independently can i pre-match volume-outputlevels, so
that i have a A/B effect, switching headphone-output to speakeroutput?
4) in a tutorial i saw i can customize buttons on the interface (for example, set MONO function on the DIM button etc..) will these
changes be saved on the interface itself, or do i have to run always TotalMix Software in the background as an seperate open
Window
5) is it possible to run the Babyface Pro FS with a Macbook Air M1, plugged into a USB3-Hub with a single USB-Cable? The
Audiofuse will even fail with 2 usb-cords (1 cord + a second supportive usb-cable) i am not able to run it, without external power
supply and it gets hot as hell...
Many thanks in advance for you help...
