Topic: Possible blown op amp
I stupidly and accidentally plugged the output of a valve amp directly into the front of my UFX, and now the DI/instrument input no longer works, and the signal light stays on.....
The remedy, please?
Cheers,
Bob.
RME User Forum → FireWire & USB series → Possible blown op amp
The remedy, please?
Cheers,
Bob.
Yikes. The remedy would be take the ufx to someone authorized to do repairs on rme devices.
Might be a good Idea to get that amp to a knowledgeable tech if you ran it with out a speaker load attached.
Ta.
The amp is fine. Only ran it for a couple of seconds.
